» Sponsors
» Sponsors
Old 01-23-2009, 11:50 PM
sc_frontier's Avatar
I wouldn't get the uprev. Get a stand alone engine management system with a professional dyno tune. A mass airflow sensor will not work for turbo applications, so you will need a manifold air pressure sensor. You probably already know this but if you run lean at any point during this project your internals could be compromised, and this is prevented with a proper tune. Adequate fuel pressure and fuel injectors running at no more than an 80% duty cycle are a must for reliability. Also look into a wide band O2 (lambda) sensor. Good luck
Old 01-23-2009, 11:54 PM
BRUTAL's Avatar
Originally Posted by xterra hines View Post
thanks for the advise!! ya that what i was planning on doing. where did you get the fuel pump from
project PTP in Austin, talk to Jon, I have the link at work saved, or you can call rich at Uprev, he has their number too
nevermind. found it
Project PTP - Your One-Stop Online Shop - Homepage
OMF street-locked Nismo wheels
Shrock skids, winch bumper, 9500# winch.PRG 10 leaf packs, Radflos, TC upper arms.
KN CAI, BFG KM2 305/70/16
Confer roof rack, aluminum tool boxes, Piaa 525 driving/fog, projector HID headlights, and fogs, Carbon fiber grill CF hood, sliders, crossdrilled rotors, EBC pads, 1 touch windows. trans VB modded, modifyed STILLEN SUPER CHARGER, 330 RWHP, NISMO T stat, UPREV http://www.youtube.com/watch?v=Sn1EvGKO1Yo
Old 01-24-2009, 12:09 AM
Loan seller's Avatar
you have a lot of turbo thinking to do. my friend has one on his gto. they are not the best option. get a pro charger. bolt on and your good to go. i am not sure if they make them for nissan. have fun
Old 01-24-2009, 12:11 AM
NissanPowerBaby!!!'s Avatar
Send a message via ICQ to NissanPowerBaby!!! Send a message via MSN to NissanPowerBaby!!!
Procharger isn't availble for our truck. Only Stillen.
2006 Nissan Frontier SE KC 4X4 6spd --Mods
General- Command start, radiator bug screen, Sony Xplod HU
Exterior-TubeTech step rails, LineX box liner, 55W 3000K Fog Lights, 55W 6000K HID's aimed up 1 1/2 turns, w/ reflectors removed
Performance-Volant Intake, Custom 2.25" DI/DO Flowmaster 50 Series SUV exhaust, 2* timing advance, WRP Crank Pulley
SHIFT_shifting
Trucks either need to be REALLY DIRTY or REALLY CLEAN, there is no IN-BETWEEN
Broken List - Stock SE rim = $457.09
People Pulled Out - Ford F-150 (2), Chevy Suburban (2), Chevy Avalanche
Kills - Mazda MX-6, Dodge Ram 3500, Dodge Dakota, Ford F-250
http://www.cardomain.com/ride/2913525
http://www.youtube.com/profile?user=cheefchin
Old 01-24-2009, 12:12 AM
uprevs website says they could tune a turbo frontier but I don't see how this is possible. They flash the existing chip. Does anyone know?
Old 01-24-2009, 01:11 AM
NissanTy's Avatar
finally someone turbo'n a vq40, the show TRUCKS! on spike tv put a remote turbo on a gen 1 lightning and it had enough power to beat a top end built 454 ss chevy truck, sure a 351 small block is different from a vq40 but the point is they seemed to get good power from it. a single (or twin) turbo for a Z would be good with a FMIC would probably be the best, but if you already have your mind set on an sts turbo set up then go for it. good luck and post pics or better yet videos of it when shes done.
2004 XE KC V6 4X4
Old 01-24-2009, 01:17 AM
X2. From what I've seen lb boost for lb boost, the STS turbo will make more power than a standard front mount turbo. It actually has near the power for psi ratio of a supercharger, and lag is not NEARLY as bad as a front mount turbo. That being said the most important thing regarding turbo lag when setting up a system is set your power goals. A proper sized turbo/plumbing is the single largest factor regarding lag. 2 smaller turbos will always spool faster and deliver power soon than one larger turbo. That being said, if you're not looking to add on 200+ whp one PROPERLY SIZED turbo will do wonders. Hell, I've seen 7 psi STS systems run an extra 100 whp...
SHIFT_shifting
Old 01-24-2009, 08:30 AM
BRUTAL's Avatar
this is how
Yes, I'm now Super Charged!!!
if you buy the cipher/osirus pack you do you own reflashes with laptop, and email tunes. without that you go to a protuner or mail your ecu to uprev for a 1 day turnaround. And NOBODY else can tune a forced induction VQ40 with the factory ecu, no piggy back, and standalones needed. you retain factory reliabilty and diagnostic capabilty and all correctly functioning subsystems, abs, body, trans etc...and as you can see from my mpg increase, the blower doesnt have costly parasitic drag. If you want more REAL info on todays tech on blowers go to Magnusons website and look at the MP90 since this IS the blower Stillen used to build their kit
  #19 (permalink)
Old 01-24-2009, 12:40 PM
ScottXGTR's Avatar
turbo lag on a remote mount is less "noticeable" because the pressure builds slower.
in a standard setup, the turbo has to pressurize 2 ft of piping.
in a remote setup, the turbo has to pressurize 12 ft of piping.
so the power gain is more gradual, instead of a quick surge of boost.
  #20 (permalink)
Old 01-24-2009, 02:41 PM
xterra hines's Avatar
if a procharger would be an opoin i would of considered it.
uprev can do the tune. and that who ill be doing it. i will also have to modify thedriver side wheel well of the intake tube. can wait to get going on this project.
First Turbo charged vq40.
sts turbo @ 6.80 psi, dt headers, no cats, uprev tune, underdriven crank pulley.
361.2 whp & 352 tq!
future mods.... transgo reprogramming kit, water to ait intercooler, cp racing pistons & connecting rods, high performance cams.
