Old 10-12-2006, 04:28 AM
LoadThis's Avatar
Send a message via AIM to LoadThis
Did i get the right sub box?
Here is a pic of the sub box that i got. I orderd it from soundoffaudio.com I spoke to the owner and he said that all the boxes that are made for the fronty are his...meaning that the mark guy is just another seller for him...which i would lead to belive for when i talked to mark he said that they dont make it...his shop in Florida makes it....and the peeps from soundoffaudio.com **** out of Fl (want to clear that up before anyone possibly gave me ****) anyway.... got the box and all...but it seems that the leg kicking out isnt as long as ive seen in others...is it the right kind? The sub i have in there isnt impresing me AT ALL so im wondeirng is air space is an issue.....
(pic is uploading)
FS: In Dash DVD Player + Extras
http://www.clubfrontier.org/forums/f...23/#post510664
2006 Nissan NISMO CC...20% tint...Nerf Bars..Billit Grille..7in Alpine IVA-D300 DVD,2 10" Kenwood Shallow Mounts, Alpine PDX-1.600, Sirius Radio, Ipod Interface, NISMO CAI, Spintec Exhaust
2005 Yamaha R6- Sold
Old 10-12-2006, 01:09 PM
shift_this's Avatar
this doesnt answer your question, but why is there another circular hole cut in the bottom of the box?
Old 10-12-2006, 02:48 PM
characterzero's Avatar
additional clearance for the magnet, i would imagine.
"These candidates make me wanna vomit in terror!" - Homer
"Go ahead, throw your vote away!" - Kang (responding to a guy who says he'll vote for a third party candidate)
Old 10-12-2006, 03:28 PM
shift_this's Avatar
so then the wood is real thin there???? that kind of defeats the purpose of using 3/4 inch wood then, doesnt it?
Old 10-12-2006, 06:02 PM
LoadThis's Avatar
thats what i was thinkin when i got it...I was like.....Hmmmmmmmmmmm ok?
anyone else with this box your imput would be greatly apreciated (not sayind anyone else wouldnt be though )
But yea i was wondeirng about that also.....Becasue at the bottom of my Sub...there is a hole at the bottom...and ive come to learn that this is there so the sub can breath...if there isnt enough spcae under that for air to travel the sub will heat up quick and/or just not work properly.
another questions as to why im not impressed at all with my system right now...once more the stock RF subs worked better (more bass) then this does....although i can now turn up my stereo another 8-10 levels (i.e. used to be not past 14, now i can crank to 22ish or so and still sound clean).
It dosnt start thumping untill 15 or so and im kinda ticked...talkin to some other peeps at the r6-forumz and they are suggesting another sub which i will try next but i dunno whats up.....
THought perhaps i got the wrong box...The one i saw on the site was longer and other peoples i have seen was longer also
Old 10-12-2006, 06:08 PM
shift_this's Avatar
just how thin is the box there? also, what sub/amp setup are you running? do you have an aftermarket HU?
Old 10-12-2006, 06:16 PM
LoadThis's Avatar
Yep....ive got....
Exactly how thin im not sure...Ill take a pic right now and post it up...Its hard to tell becasue it looks like a bigger cut then it pertrudes (sp?) out at the bottom....you can see in the pic.....
Head Unit=Alpine IVA-D300 In dash dvd player.
In dash DVD installed
Amp= Alpine MRP-M450 225 rms@ 4 ohm and 400 rms @ 2 ohm.
http://www.bestbuy.com/site/olspage....=1134701297803
Sub= RF Punch 2 10" 200 RMS 400max at 4ohm SVC
http://www.bestbuy.com/site/olspage....=1134701324631
I can stack 4 pennies from top to bottom untill its flush to give you somewhat of an idea
Old 10-12-2006, 06:32 PM
06NISMOCrew's Avatar
I have the same box. I ahve a Rockford Fosgate Phase 2 10" DVC in in it and it sounds good. They cut the hole in the bottom and glue another piece of wood to the bottom over the hole so that at the point where the magnet goes down there is extra depth to allow for a larger variety of subs (not just shallow mount) There is another version of the box that is longer and goes all the way over to the drivers side that gives you more volume. The speaker that I have doesnt require that much volume though the air space of the smaller box is actually right in the middle of the spec for box volume. Can I ask what speaker and amp are you running?
Opps, Sorry I didn't see that last post.
The Fosgate sub you have is it single vcoice coil or dual?
2006 NISMO Crew Cab 4X4
http://www.cardomain.com/ride/2839600
Last edited by 06NISMOCrew : 10-12-2006 at 06:34 PM. Reason: Automerged Doublepost
Old 10-12-2006, 06:39 PM
LoadThis's Avatar
Single Voice Coil.....I thought when i was ordering i got the DVC but nope....You think that would make much of a diff?
also what amp are you using? And what is your def. of sounds good? Mine sounds decent also and all..but its verry inconsitant...eh i dunno
Old 10-12-2006, 06:51 PM
The link you provided is to the Dual Voice Coil Sub. That is the one I have.
I'm using the Fosgate 300.1 Mono amp that puts 300 Watts at 2 ohms. I have my dual voice coils run in parallel to make a 2 ohm load.
I don't know that the DVC vs. the SVC would make that much difference. My definition of sounding good is that this single ten actually thumps harder that the two 12" fosgates I had in my last car. Being that it's a truck and the speaker is right there and not in the trunk helps a little. It's loud let me just put it that way. My wife can hear me a block away coming home from work at night.
Also, your head unit only has a 2 volt pre-amp output. My head unit has a 5 volt pre-amp output. Don't really know how much that helps though.
Last edited by 06NISMOCrew : 10-12-2006 at 06:53 PM. Reason: Automerged Doublepost
