I have individual pictures of the wheels as well. The wheels do not have tpms but I do have the factory lug nuts that I'll throw in with them. If anyone needs any more details or pictures feel free to pm me. I will also clean up whatever item you are interested in before I ship/sell it. Thanks!
There was concern from another member that the holes in mud flaps are damaged. They are not, the holes where the screws go are supposed to be oblong to allow for adjustment while installing. Thanks again gents!
I'll clean it up before it's sold. Just dirty from sitting in the garage. Never installed on my truck but another member here has pictures of it on his truck. I'll see if I can find them
As far as I know they will mount with the screws that are already in the wheel well. When I removed mine I put the screws right back into the holes I took them out of so I assume that's all you need. Maybe someone else could confirm or correct this?
Interested in the mud flaps. Are these OEM or after market like the dodge and jeep that the link goes to on the amazon page? Any difference in fit to the body on an SE vs you SV? Can you box and ship? any cheap way to ship is fine. Broken down truck probably going nowhere soon. d
These are oem nissan mud flaps. There shouldn't be any difference in the wheel wells. I'll ship them no problem. Got someone in line for them already but if it doesn't go through I'll let you know.
Yes, let me know. I will take them if not damaged. 1 looks cracked and repaired in the picture but your other post said no damage so planning on going with that. My truck is black and the mud washing off the neighbor's property into our drive this year has my tires picking up gravel in the drive and looking horrid. Thanks. d
Yes you will be able to access both sides so a nut and bolt should be doable.
For your entertainment, a pic of the mounting hardware that comes with the flaps. Out of the bag 1 of 2 push pins and a snap-in nut and screw (1 of 8 ). The bag shows a part number so maybe your dealer could get it? Or if possible some plastic bolts and nuts at a local hardware? Or some that won't rust...
