This information is for all of you who have installed or are thinking about installing an aftermarket transmission temperature gauge. I installed an Autometer Phantom II gauge (2 1/16") in the round blank port for the NON four wheel drive Nismo CC. There has been alot of people on here that say the 1/8" NPT sending unit fits the pressure port next to the IN and OUT cooler lines on the transmission. I have done all of the research and have listed the CORRECT adapter and sending unit needed to correctly install an Autometer gauge.
Autometer Phantom II Trans. Gauge 2 1/16" (part # 7549)
Autometer Short Style Sending Unit (part # 2259)
Autometer Metric Adapter M10-1.0 to 1/8" NPT (part # 2265)
The sending unit that comes with the gauge is too long for the transmission, so you will not be able to use it at all. You have to purchase the short style sending unit to fit into the metric adapter.
SO EVERYONE KNOWS, 1/8" NPT IS NOT THE SAME AS M10-1.0 AND THEY ARE NOT COMPATABLE. IF YOU DO USE 1/8" NPT ON OUR TRUCKS IT WILL LEAK WITH TIME.
I hope this will help everyone out in there future installs and corrections.
If you notice in the picture I moved my "Diff Lock" switch over to the last port. I just didn't want the wires to be to close together. Different look!
__________________ 2005 NISMO CC 4X2---Bassani Stainless Cat Back, Injen Cold Air Intake, TFU Custom Motor Mounts, P265/75R16 Michelin LTX M/S 2, Stillen Differential Cover, Custom center console mod, Custom skid plate with larger oil filter access panel (diamond plate), LED conversion (all lights), TB Coolant Bypass, Trans. Radiator Cooler Bypass, Transmission Temperature Gauge install, Differential Breather relocation mod (behind passenger tail light)
Reason: Update
The Following 5 Users Say Thank You to cps For This Useful Post:
Yes you are correct, the adapter part number is 2265 (not 2266). As far as pictures go I will try to take some this weekend and get them posted. I edited my first post and changed the metric adapter part number.
Devius1, the metric adapter's center hole is not large enough for the probe end of the sender to go through, so Autometer makes a short sender version that does away with the long probe. It just fits into the end of the adapter.
Reason: update
Step by step pics would have been nice when I put it in, but I have a 3 month old son who keeps me busy ALL day long. I did all of this work between the hours of 11:30 pm and 3:00 am.
The one thing that was important to me was to do this entire install without splicing into any of the factory harnesses. I did this by buying a trailer electric brake wiring harness that plugs in to a male plug under our dash. I took apart the harness and changed some of the pins around and took out the ones I did not need. I got a constant power 12V, switched power 12V, ground, and a TRUE 12V illumination wire. This last one is very important because all of the dash lighting is LED and doesn't need a full 12V. When you by an aftermarket Autometer gauge it requires a full 12V even though it is also LED. If I remember correctly I was reading 1.43V when I checked LED power source for the radio.
I will try to write up more but its time to feed my son. Hope some of this helps.
The Following User Says Thank You to cps For This Useful Post:
awsome idea of getting a wiring harness to tie into, but where is the plug located under the dash? Thanks for the tip and I would love to see a picture of the harness wired up and of the dash zoomed out. I have the autometer #6349 that I'm going to put in soon.
