» Sponsors
» Sponsors
  #101 (permalink)
Old 07-02-2009, 10:57 AM
ToddG's Avatar
Originally Posted by Triple S View Post
I'm trying to find a dyno pull graph of the 4.0 Frontier with the Superchips, I have not found one, so what I'm seeing in the chart has nothing to do with Superchips. I'm wondering if
A- I can find a Superchips graph
B- Does the Cortex help out this strange drop
Here ya go Trip:
Who's da man? What's that? ToddG you say? Ha!
Chart is from an X but same motor.
18.3 more peak HP! Yeah baby.
The Following User Says Thank You to ToddG For This Useful Post:
Triple S (07-02-2009)
  #102 (permalink)
Old 07-02-2009, 11:38 AM
Send a message via AIM to scuba91ta
That is likely the point at which the variable intake flaps open up, causing some bog on the motor... probably could be tuned out to some degree...
2005 Frontier KC Nismo, Nitto TG 285/75/16's, PRG 2" Spacer/1.5" Blocks, SuperChips Tuned
1991 Pontiac Firebird - "Evil TA" - 12.08 @ 114 N/A
  #103 (permalink)
Old 07-02-2009, 11:40 AM
Triple S's Avatar
Originally Posted by ToddG View Post
Here ya go Trip:
Damn, over, and over, and over you keep being there to help me out.
You sir have a great holiday weekend!!!
Thanks, and I made this one official
Triple S • SILLY SUBSTANDARD SLUSHBOXES
  #104 (permalink)
Old 07-02-2009, 09:42 PM
Here ya go Trip:
I'd say even the SuperChips still shows the same thing. If you look close you can see the same "dip" at around 3700 RPM. This Dyno chart IS "smoothed." A lot of good dynos have the ability to "smooth" the curves so they aren't as jagged or pronounced. This one is WAYYYyyyy too smooth for a non-smoothed reading.
The dip is there. And it is almost certainly something mechanical in the way the engine operates. I'd be inclined to agree that it is like the variable intake kicking in.
2008 CC Nismo 4x4
2.5" lift - leveling kit, Nerfs, bull bar.
Pioneer PH-8000BT, Garmin GPS holder, CAI, SuperChips
  #105 (permalink)
Old 07-03-2009, 12:35 PM
2WD_NISMO's Avatar
It definitely shouldn't bog down in power though, with or without a tune, if you guys are feeling that there's something not right.
2005 with NISMO CAI, JBA Cat-Back, WRP IMS + CP, e-fan, S-chip and some exterior changes...etc.
  #106 (permalink)
Old 07-03-2009, 06:44 PM
That's not really true that something is wrong. The "butt dyno" shows it as a "plateua" before what feels like a strong launch. In other words, the power is still there but a little "flat" for just a moment and then it takes off like a scalded cat...
As has been mentioned, it may be related to the variable intake changing up at that point.
2008 CC Nismo 4x4
  #107 (permalink)
Old 07-04-2009, 06:55 AM
2WD_NISMO's Avatar
^ Well then, lucky for me as I have an auto so I don't feel any "bogs."
  #108 (permalink)
Old 07-04-2009, 07:21 AM
I have an auto as well and I don't feel it as a "bog" but rather as a slight "plateau" and then WHAM!, the power comes on hard. That can still be the "dip" in the power band.
2008 CC Nismo 4x4
  #109 (permalink)
Old 07-07-2009, 08:32 AM
Your changing how the air flows through the intake... it's going to drop because different length runners change HP and torque curves...
  #110 (permalink)
Old 07-07-2009, 08:59 PM
I'll go a step further. Look carefully at the power curve. We're talking about a 200 RPM range here. I DARE you to get in your truck, stick the throttle HARD through that RPM zone and it will pass so fast you will almost not even notice except that the butt dyno will kick a little hard as it PASSES 3700 RPM.
2008 CC Nismo 4x4
Sponsored links
