» Sponsors
» Sponsors
Closed Thread
  #91 (permalink)
Old 03-22-2009, 01:40 PM
2WD_NISMO's Avatar
Looks like you are making good progress. Are you doing it alone?
2005 with NISMO CAI, JBA Cat-Back, WRP IMS + CP, e-fan, S-chip and some exterior changes...etc.
  #92 (permalink)
Old 03-22-2009, 01:46 PM
AndrewVK's Avatar
Feedback Score: 5 reviews
me and my brother. and a bit of electrical help from step dad. but other than that its just us two. im about to get dressed and finish tearing down the vk
Friten
Mods list and pictures
8 cylinders of sex on your face
  #93 (permalink)
Old 03-22-2009, 02:20 PM
bigdog's Avatar
Feedback Score: 3 reviews
interesting... will keep an eye on this project!
2006 SE CC 4x4 A/T: NISMO CAI, JBA Exhaust, Unichip PNP, Fabtech 6" Lift w/PRG UCA and Radflo 2.0, ProComp 7089 w/Nitto Terra Grapplers (295/75R16), ShrockWorks Skid Plates and Front bumper w/Warn M8000 and Hella 500s, M226 swap w/ ARB Air Locker and Compressor, UnderCover Tonneau, CW Billet Grilles...
“A government for the people must depend for its success on the intelligence, the morality, the justice, and the interest of the people themselves”. - Grover Cleveland
Bigdog's Build Thread
  #94 (permalink)
Old 03-22-2009, 02:41 PM
Inyourface1650's Avatar
Originally Posted by ElLlanero View Post
no im a v6 manuel.... and even then the fronty a/t are still different from titans. and mmm i dont mean to burst your bubbles but using titan motor mounts and brackets are not going to work. i would think cause the frame on a titan is wider them ours. i was thinking maybe brackets and engine mounts from the 09 V8 paths might work. let me know if it works or not.
when you put in the titan front suspension, and the titan differential, and the titan axle shafts it all bolts up fits? Which means the lower control arms are the exact same width as they are on a titan, which means the frame is the exact same width as a titan.
SirLurksAlot
  #95 (permalink)
Old 03-22-2009, 02:52 PM
AndrewVK's Avatar
lol
Friten
  #96 (permalink)
Old 03-22-2009, 04:02 PM
SandToy05's Avatar
Originally Posted by Andy4106 View Post
motor mounts. in case you cant tell the difference, the dirty one is mine.
Pwned
I think the mechanical aspects of this project are the easiest. We know it's the same frame, suspension, motor mounts, etc. The hard part will be the electronics. Since the 4wd system and everything else is all tied together, it'll most likely be a full swap to Titan harnesses all around.
Keep up the good work! I'll be installing my new (used) Stillen supercharger next weekend, so hopefully you don't finish this project by then and make me wish I never bought it
2005 Frontier Crew Cab SE 4x4 AT
Performance: Eaton MP90 supercharger, Stillen air/water intercooler, Stillen fuel rails, 550cc injectors, Volant cold air intake, true dual 2.5" Flowmaster exhaust, UpRev Osiris
Suspension: Titan mid-travel swap, M205 diff, King 2.5" remote rezzy coilovers, Deaver spring pack, PRG shackles, PRG Bilstein 8" rear shocks, Cooper STT 285/75/16 tires, u-bolt flip, rear axle breather
Interior: Infinity Kappa 693.9i fronts, 63.9i rears and 10.9T tweeters
Appearance: Stillen battery tie down, Optima Yellow Top battery, NISMO oil cap, NISMO radiator caps, de-badged tailgate, relocated hitch plug
Coming Soon: long tubessssss
  #97 (permalink)
Old 03-22-2009, 04:16 PM
AndrewVK's Avatar
lol it will be done in a week or so i can promise you that much. all that im waiting on is the exhaust. that comes in tomorrow, and the engine will be put in, and i will driving it around in 2wd untill i can get the harness fixed or buy another.
Friten
  #98 (permalink)
Old 03-22-2009, 11:22 PM
ok guys. understand that im taking a v6 truck, with 6 holes in the motor, and putting a v8 motor in that truck, with 8 holes in the motor. i understand that the motor will be longer, bigger, ect. i have thought this out since last year. the bell housing bolts up. and the motor mounts are the same off the frame and the same clamshell....
I wasn't trying to be a downer, just putting info relevent to your cause that you might not know. Like I said, I'm sure there is a workaround as there are 5.6 Xterra's out there but it might not be the drop in affair that we all hope it to be. Apearently Nissan had to stretch the Pathfinder front end to drop that motor in so it might mean some relocation, cutting, or what have you to get it to fit propperly.
Anyway's, good luck.
  #99 (permalink)
Old 03-22-2009, 11:29 PM
toyniss's Avatar
^^^^^^^^dude read some more. the pathfinder frame is probably different than the rest or we dont know that?, but the titan/frontier/and X frame as we know it are the same. and the X that you are talking about 5.6'd has stated that the motor was a bolt in with some electrical issues.
CALMINI sucks!
  #100 (permalink)
Old 03-22-2009, 11:37 PM
05cc4x4's Avatar
Feedback Score: 4 reviews
If I remember right the guy that did the Xterra V8 used an electric fan. The stock clutch driven one on the V8 stuck out to far which is probably why you read about front end mods. I have a Frontier, A Pathfinder and my sister has an Xterra. All of them have the exact same engine bay, so if you can stuff a 5.6 in an Xterra it will fit in ours. The guy that did the Xterra was a Nissan Engineer and he was ready to help everybody out and then he dissapeared. I think the lawyers got to him. He said the hard part was all electrical. The original thread is probably still on the xterra forum but I'm to lazy to go look for it.
I found a couple of the pics from that thread
White 05 LE crew cab 4x4. Mods so far- Rollbak bed cover, custom Yakima bike rack, Pathfinder center console, Pathfinder window trim, steering wheel audio controls added, vent visors and window tint.
Closed Thread
