» Sponsors
» Sponsors
  #161 (permalink)
Old 07-07-2009, 08:07 AM
callen81's Avatar
I wonder if getting an aftermarker upgrade intercooler for the D40 desiel would work, we should have the mount points for one? That barrel intercooler looks pretty cool but I wonder how well it works, I have a 93 NX with a sr20det swap and I have no room for an intercooler other then cutting my hood.
  #162 (permalink)
Old 07-07-2009, 08:10 AM
SandToy05's Avatar
Originally Posted by callen81 View Post
I'm sure a ecu map change and some cams would over come those issues. Our longer stroke would also help in the lowend torque department.
It's not going to overcome differently-shaped ports and intake manifold runners, though. At this point, since you're already changing the cams and ECU, you might as well just extrude hone the stock VQ40 heads and throw a set of cams in those. I can pretty much guarantee you'd have better results and spend a whole lot less money than getting a custom cam designed for 370 heads on a truck lower end.
2005 Frontier Crew Cab SE 4x4 AT
Performance: Eaton MP90 supercharger, Stillen air/water intercooler, Stillen fuel rails, 550cc injectors, Volant cold air intake, true dual 2.5" Flowmaster exhaust, UpRev Osiris
Suspension: Titan mid-travel swap, M205 diff, King 2.5" remote rezzy coilovers, Deaver spring pack, PRG shackles, PRG Bilstein 8" rear shocks, Cooper STT 285/75/16 tires, u-bolt flip, rear axle breather
Interior: Infinity Kappa 693.9i fronts, 63.9i rears and 10.9T tweeters
Appearance: Stillen battery tie down, Optima Yellow Top battery, NISMO oil cap, NISMO radiator caps, de-badged tailgate, relocated hitch plug
Coming Soon: long tubessssss
  #163 (permalink)
callen81's Avatar
Originally Posted by SandToy05 View Post
Turbo lag is relative. I'm saying he will have much more lag than he would with a properly placed turbo about 10 inches from the cylinder head port. A small A/R ratio also has the effect of choking flow to the turbine wheel causing a hose of other issues if you don't size it properly. Again, do some reading before you post nonsensical arguments.
Yes, I know this. However, most people on this forum off-road their truck in some capacity, so the STS kit will not be a viable choice for them. In his small single instance, it may be viable.
Yes, ten years ago. What's so funny about that? You don't think dynamometer technology has changed in ten years? Quit reading Super Street magazine.
Turbos don't make much torque?? Where are you getting your info from??? My Turbonetics kit made more torque than HP, 397whp 404wtq @ 8psi to be exact LOL
Okay, I'll rephrase that statement... "your turbo engine will never make low-end torque the way a supercharger will. Turbocharged engines will flat out NOT EVER have the same torque curve that supercharged engines do. That's an indisputable fact. As for my info, I'm getting it from every single dyno chart I've ever looked it in my entire life. Happy now?[/QUOTE]
What about dualscroll turbos? :P Those have nearly instant torque. Unlike a supercharger they also have a good top end as well.
  #164 (permalink)
Old 07-07-2009, 08:11 AM
SandToy05's Avatar
Anytime you have an abundance of ambient airflow, an air-to-air intercooler is better. Just keep that in mind. I'd rather do some cutting than install an air-to-water setup any day.
What about dualscroll turbos? :P Those have nearly instant torque. Unlike a supercharger they also have a good top end as well.[/QUOTE]
He's not using a dual-scroll turbo and they do NOT provide "instant torque". You are thinking of a variable-vain turbo, and good luck finding one on the aftermarket and getting it to work properly.
And if he was to spend massive bucks on a variable vain turbo, then all I have to do is get a twin screw supercharger. Bingo, instant top end.
  #165 (permalink)
Old 07-07-2009, 09:24 AM
BRUTAL's Avatar
Originally Posted by xterra hines View Post
ihey brutal, arent our ring packs on our pistons really high? makes for a weak piston?
YES, AND THATS WERE MY #4 PISTON FAILED. THE NEW CP'S I HAD MADE ARE NOT ONLY FORGED, BUT THE RING PACK IS ALITTLE LOWER FROM THE TOP. THE REASON MANUFACTURERS RAISE THE RING PACK IS IT REDUCES EMMISSIONS, AND IMPROVES MPG. BOTH OF WHICH ILL PASS ALITTLE ON FOR MORE STRENGTH
OMF street-locked Nismo wheels
Shrock skids, winch bumper, 9500# winch.PRG 10 leaf packs, Radflos, TC upper arms.
KN CAI, BFG KM2 305/70/16
Confer roof rack, aluminum tool boxes, Piaa 525 driving/fog, projector HID headlights, and fogs, Carbon fiber grill CF hood, sliders, crossdrilled rotors, EBC pads, 1 touch windows. trans VB modded, modifyed STILLEN SUPER CHARGER, 330 RWHP, NISMO T stat, UPREV http://www.youtube.com/watch?v=Sn1EvGKO1Yo
  #166 (permalink)
Old 07-07-2009, 11:11 AM
^^^ Are you looking for pics of the pistons, cams, rods, supercharger, turbo's, etc.....
They have covered a lot of stuff so far.
Basically the different options to boost the VQ40 and what the VQ40 is built of, ie VQ35/37Hr bottoms and the VQ35 heads.
07 SE CC Auto
  #167 (permalink)
Old 07-07-2009, 01:40 PM
BRUTAL's Avatar
UH, JUST TO CLARIFY DOOBIE, CAUSE YOUR POST SEEMS VAGUE TO ME...THE VQ40 BOTTOM END, BLOCK ETC SHARES NOTHING I KNOW OF WITH THE 3.5, 3.7. OUR HEADS ARE THE SAME AS 3.5, ONLY WITH DIFFERENT CAMS(OURS HAVE MORE LIFT) AS FOR DURATION I NEVER GOT A DEFINITIVE SPEC, AND BOTH CAN BE CHANGED TO ALLOW FOR DIFFERENT RESPONSES IN THE RPM RANGE THROUGH VVT TIMING
  #168 (permalink)
Old 07-07-2009, 08:28 PM
I like the idea of someone trying to turbo but it wouldnt be for me. Keep up the work.
Rusty Bumper
  #169 (permalink)
Old 07-07-2009, 11:15 PM
xterra hines's Avatar
yes it would be cool! and thanks for the support sweaty! haha funny name. and also i called the shop today, they installed the fuel pump and its working fine, there was some small fitment issues with the walbro but it works just fine. im happy to hear that, and turbo is mounted and fitted. now oil lines and pump placement . they are going low as possible. then they need to do injectors, tunning and bam. we are cooking
First Turbo charged vq40.
sts turbo @ 6.80 psi, dt headers, no cats, uprev tune, underdriven crank pulley.
361.2 whp & 352 tq!
future mods.... transgo reprogramming kit, water to ait intercooler, cp racing pistons & connecting rods, high performance cams.
  #170 (permalink)
Old 07-08-2009, 12:44 PM
Ha thanks. Ill get some pics up by tomorrow of the progress
361.2 whp & 352 tq!
