Originally Posted by 2WD_NISMO
Smooth or rifled bore?
We will most likely experiment with smooth throttle body spacers. But this will be after the first kit has been developed.
Originally Posted by tomtom
Understood, I am just saying that the fact that you are experimenting with a variety of thicknesses and combinations to come up with one that works best for us is awesome! I don't subscribe to the notion that more is better, in fact I often assume that "less is more" So if its upper and lower spacers, spacer and tbs, spacer only we can feel confident that you've experimented with a variety of combinations and come up with the best one.
As for what the majority wants, I agree with the notion of creating a poll to determine that. My vote would be for power over speed, and frankly with gas prices where they are improved fuel efficiency would be a great selling point too.
BTW - Thanks for doing this I hope that it becomes a win-win situation.
A gain in gas mileage is always a plus. But I have yet found a way to
noticeably increase gas mileage with just using intake spacers. But, the improvement in airflow with our port matched spacers and increased low end and midrange torque will definitely help gas mileage at cruising rpms. But we have not been able to prove a noticeable gain. One thing is for certain though. That with all our spacer kits, not one of them has shown a decrease in gas mileage. It can only help.
Also, when you say 'power' over 'speed', what exactly do you mean? Some people think 'peak HP dyno numbers' when they hear 'power'. These spacers will not increase the engine's peak HP numbers. But they will significantly increase the low end and midrange power. They will most likely sacrifice a little top end power though. That is why we have to test more than one thickness to see which is best for this engine.
Also, when you say 'speed', do you mean strictly acceleration numbers? Speed and Power tend to go hand and hand. But some people are willing to give up, say, 5-10hp above 5K rpm in exchange for an increase of 30hp below 5K rpm. That is probably b/c they tow a lot or do a lot of off roading and spend a lot of time below 5000rpm. But some people are solely interested in the truck's ability to accelerate as fast as possible from 0-60mph or in the 1/4 mile, which involves spending a lot of time above 5K rpm. If that is the case, a big top end loss is unacceptable. I definitely vote for improvement in acceleration numbers regardless of what kind of shift you see in the torque curve. So a thinner spacer would be needed for this, probably between 1/4" to 1/2" thick. But, for those that are willing to sacrifice top end power in exchange for lots of low end torque and more throttle response, a 1/2" - 3/4" thick spacer may be best.
Thanks for your input.
Originally Posted by ToddG
0-60 would impress me more than what's going on at 90+mph like in the 1/4 mile.
Remember, it's not how fast you go it's how fast you get going.
Yes, I agree. So, a large shift in the torque band probably won't be best for making the most power in the area used most between 0-60 or 0-95 (like in the 1/4 mile). Sure, a thick spacer will provide a huge increase in throttle response and partial throttle power and your truck will certainly "feel" fast from stoplight to stoplight. The fun factor will be there. But it may hurt top end power so much that your 1/4 mile times could actually be hindered.
So one thing I will determine during testing is exactly which area of the power band is used most during wide open throttle acceleration runs. Once I determine the area that is used most for 0-60 and 0-95mph runs, then I will be able to know which spacer will actually make your truck faster, rather than which one just makes it "feel" faster.
