Here is a spot to post all of your Sound and Video clips of different exhausts.
Please try to List
1. Brand and/or model number and description of exhaust setup. 2. Engine in your vehicle. (2.4, 2.5, 3.0, 3.3, 3.5, 4.0, etc.) 3. Description of Vehicle (Year, trim package) 4. Cost estimate 5. Link to clip
Also: Please keep comments about others exhausts to a minimum to make this thread easier to search.
Just noticed the sticky. Ill post up what ive done, maybe it can help some people out or what not. Its a Cat-Back design 2.5" off each cat, running into a flowmaster 2.5" to 3" Y-pipe. Then the muffler right after the Y-pipe and a piece of 3" tube bent at a 90* ( compression bend)angle and turned slightly down so it exits just before my pass rear wheel. Sounds amazing for this motor if you ask me.
i thought i would try to get some better vids of my exhaust sound so i did some more clips and tried editing them together. it was my first attempt at editing but i think its ok. i wish i had some one to help me with the drive by part but it was the best i could do by my self. hope you enjoy and let me know what you think.
Bassani clips here. My truck is an 05 Nismo V6. Cost for the stainless system was $525 shipped with a group buy discount. The system is a single in single out. The tip actually has a resonator in it too and the system re-uses the stock vibration damper. Build quality is very high.
Picture of the tip is on Badbrad238's truck. He has the same system and we did our install together.
1. Bassani Aft-Cat Exhaust System Part# 400515 (Stainless Steel) 2. 4.0L V6 3. 2005 King Cab Nismo 6 Speed 4. $525 for system, $14 for 4 new flange nuts (could only get them from dealer), $8 for a bottle of anti-seize goop
5. Enjoy these clips (I still have to get exterior drive by's)
Cats Only: http://www.youtube.com/watch?v=plBw4C6PukI
I'm impressed with the 3rd gear rubber. I can barely get rubber in 1st gear anymore now that I have the 18's with the Falkens. They are sticky as all get out. Sorry for the thread jack but to get it back on track your exhaust sounds killer.
My only gripe is that it has some resonance at ~2.1k-2.8k when under heavy load. I might add resonators later if it gets too annoying. Other than that, I couldn't be happier with this setup. Also, credit to HKYStormFront for the dual out the side idea ... I love it!
