Thought it was a good time to update this. Haven't done a whole lot on it but did get some stuff accomplished so here we go...
Bought an airtank for the ARB, but re-plumbing the air system will be waiting for better weather so that's on hold.
(Picture #1). I asked for a tool box for Christmas, and due to that, I needed to move the CB antenna mount so I could get the box as close to the cab as possible. Seeing as how off the shelf stuff didn't suit my needs, I made a new CB antenna mount out of 3/16" aluminum. Made an aluminum plate out of 3/16" too that slides into the utilitrak and tapped two holes in it for the bolts
(Picture #2). The tool box I asked for. Very cool piece. Got a little banged up in shipping but nothing that I couldn't pound back out.
(Picture #3). This is the new gauge console I built. It's made out of 16 gauge aluminum and covered in some grey headliner material I got at JoAnn Fabrics. The black gauge plate you see I had made by
Gauge Plates. These are temperature gauges for the front and rear diffs along with a spot for the front and rear locker switches. In the spring I will be replacing the E-locker with an ARB and I am hopeful that they (ARB) will have something for the M205 at that time. I decided to just go ahead and wire them up now instead of pulling it all back apart later. I replaced my Ultra Lite gauges with Ultra Lite II's because I was having a hard time seeing the Ulta Lite's at night. The II's do not have actual diff temp gauges so oil temp gauges were substituted and I had the gauge plate made with the words "Rear Diff" and "Front Diff" imprinted on them. They light up amber at night (the words, not the gauges.) The gauges light up white through the dial and have red needles. I will get a night time shot of the whole dash lit up and post some picutres of the console on my work bench after it was assembled so you can better see how I built and wired it.
During this project I took the time to re-wire some of my previous work. I had tappped the dash light circuit in the engine fuse box and ran that to a relay on the engine fuse/relay panel I built, then to the gauges in my A-pillar. This time, I cut that wire and ran it from the relay to an 8-way distribuition block to use as a (+) stud. I bolted that up under the dash below the steering wheel. That stud now sends power to all the gauge lights and the switch lights so they come on only when the dash lights are on. Similarly, I used another 8-way distribution block to create a ground (-) stud that the grounds for all the new stuff I added go to, then ran a fat 12 gauge wire up under the dash as a ground strap. All the power to run the switches and the gauges still runs from the ignition hot fuse box I added in the drivers side kick panel area.
The Front Diff and Engine Oil Temp gauges are not hooked up yet. I will be re-doing the way I have the Oil Pressure sender hooked up so I have to drop the engine skid to do that. When I get to that is when I will hook up the other two gauges.
EDIT: Completely forgot to mention that I got to go wheeling with my buddy John (hard2kill). Nothing crazy, just some trail riding in the woods. Good for a shakedown of the truck though. Should've tried the one hard obstacle but after seeing John's Toyota get denied, I thought better of it. I just wanted to test the truck to make sure there wasn't any strange noises or binding or anything. Pleased to report the ole girl did great. Somewhere, someone has a picture of me posting up on an old train bridge retaining wall and there's a video coming over a little crest and down a slope. No idea where those are though. It was a good day with good people though and that's what counts.
