Finally feel like I've done enough work to the truck to warrant a build thread.
There are links to some of the threads I started that contain good info on the exhaust build, UpRev tuning, front bumper/OBA/Aux Electrical setup and the installation of the oil pressure gauge. Pictures are sporadic because I didn't take a picture each and every time I built/changed something but it's a pretty good overview of what I've done so far.
Thank you to:
Vicki - My Girlfriend of many years who lets me do all this crap
Drew and Cassie - Drew for helping build it and Cassie for keeping Vicki entertained while we built it
Gutter Greg - For going wheeling, helping build it and reminding me of the virtues of slowing down
Mustang Bill - For helping build it when I really needed someone else
Toyota John - For showing up with the sawzall at the precise moment it was needed
TRUCK - 2009 Nissan Frontier King Cab PRO-4X 4x4 6spd. Bought it brand new April 25, 2009. Rolled it off the lot with 21 miles on it. As of the writing of this build thread I have 103,650 miles on it (give or take.)
LINKS
Another Exhaust Thread... Need Advice. - Headers/Dual Exhaust Install and Build
UpRev Standard not available? - Slog through it to the payoff with the dyno sheet
Mike/westracings new bumper - Front Bumper, Tire carrier, Diff Temp gauge and OBA/Electrical system are all in this thread with pics
How To (Sort of): Install Aftermarket Oil Pressure Gauge - Self explanatory
ARMOR
* Shrockworks Front Winch Bumper with Prerunner Hoop
* Shrockworks Rear Bumper
* Shrockworks Sliders
* Shrockworks Radiator, Engine, Transmission, Transfer Case and Fuel Tank Skid Plates
EXTERIOR
* CBI Offroad Fab Swing Away Spare Tire Carrier with Jerry Can Mount (the Shrock rear was modified to fit the carrier)
* WARN XD9000i Winch with Synthetic line and wireless remote
* OBA Quick Connect on front bumper
* Firestik 4' CB Antenna mounted to utili-trak behind the cab
* Rigid Industries 20" LED bar on front bumper
* Rigid Industries Dually's mounted to top of bedrails
* 85HP worth of decals in the back window
* UWS Aluminum Black Diamond Plate Tool Box
INTERIOR
* Brutal Gauge Pod
* Autometer Ultra Lite II Oil Pressure and Engine Oil Temp gauges in A-Pillar
* Autometer Ultra Lite II Oil Temp Gauges for Front and Rear Diff in custom Gauge Console in front of shifter
* Custom Shift Knob
* OTRATTW switches mounted next to shifter and on custom console in aluminum bezels
* Cobra 29 50th Anniversary Edition CB mounted to top of dash above stock radio
* Autovation Pedal set and heel plate
* Scangauge II on Blendmount
* Gentex Auto Dimming Mirror with Compass and Temp
* Tigger Koosh
PERFORMANCE
* INJEN Cold Air Intake modded with a separate tube to draw air from the fender
* NISMO Shorty Headers
* WRP Intake Manifold Spacer
* True Dual Exhaust with twin Borla Turbo Mufflers (pipes cut by passenger rear shackle)
* UpRev Tuned by Performance Motorsports East (266 HP/275 FTLBS backed up by dyno sheet however the truck actually pulled 270 HP/280 FTLBS on last run)
* PRG Short Throw Shifter modified to accept any Hurst 2 bolt shift lever (now has custom lever)
SUSPENSION
FRONT
* PRG Titan Heim UCA
* OEM Titan LCA
* Sway-A-Way 2.5 Remote Reservoir Coilovers with 650lbs springs
* PRG Heim Steering
* PRG Extended Brake Lines
REAR
* Deaver 10 Pack Race Leafs
* Bilstein 5125 Shocks
* PRG Adjustable Shackles
* U-bolt Flip with Ruff Stuff parts
* 2" Wheel Spacers from Fred Goeske at wheeladapter.com
DRIVETRAIN
* Titan M205 Front Diff re-geared to 4.10
* OEM M226 Rear Diff with E-locker re-geared to 4.10 (Going to an ARB Locker in Spring)
* Mag-Hytec Diff cover
WHEELS/TIRES
* 5 OEM 6-spoke PRO-4X rims
* 5 255/85R16 BFGoodrich Mud Terrain KM2's (Pizza Cutters)
MICELLANEOUS
* ARB CKMA12 Air Compressor mounted in engine bay
* Odyssey AGM Battery
* Custom designed and built Auxilliary Electrical System (100A breaker, 2 Blue Sea fuse boxes, one constant hot and one ignition hot)
* 60" Hi-Lift Extreme
* Allstar Performance Vented Breather Tanks for Front and Rear Diffs
The day I brought it home...
First came the sliders, skids, rear bumper, new tires... Then I went wheeling (see attached)... Got some sweet trail damage when I nailed a rather large rock...
