The Build page. The attempt to construct a daily driver trail rig that will be capable to expedition the great United States. Some minor improvements to an already capable truck that has been a blast to take into the forest.
Username: sixspeed-sv
Year: 2011
Make:Nissan
Model: Frontier
Trim: SV
Color: Avalanche
Mods:
Interior:
-communication: Cb Uniden520xl [right channel radios] truck package. Wilson antennae.
aftermarket seats - see build.
-dash cover grey
Exterior:
- right fender dimple - hollister hills - winter 2011 :censor:
-left fender contusion - healdsburg utility pole - spring 2012 :censor:
Drive train:
4.10 locked differentials front and rear - ARB air setup.
Performance gear set through Rugged Rocks - Thanks!
onboard air tank - drivers rear 1/4 panel - fits nice like.
Suspension & Tires:
-PRG Advanced kit: radflow coil over spring set, Deaver Spring Set, Bilstein Shock, Upper Control Arms (UCA).
- stock tire -Long Trail At - shredded lugs and side walls - thank you Nevada - labor day wheeling.
Rubber: 285/75/16- Les schwab house brand AT3 2nd set.
Armor:
-Hefty Fab Skid Plate package.- Belly Armor
-Hefty Fab Rock Slider with side step
-PRG rear differential Cover
Performance:
- PRG short throw shifter..
Gear and Other:
1.75 gallon x 2 frotopax fuel- see build
In Progress:
under chassis lighting
Year: 2011
Make:Nissan
Model: Frontier
Trim: SV
Color: Avalanche
Mods:
Interior:
-dash cover grey
Exterior:
Drive train:
Suspension & Tires:
Armor:
Performance:
Gear and Other:
In Progress:
