I did the same as xmod. I put the wire in that black wire sheathing and used this stick on zip tie tie downs. Its not the cleanest install but its super easy and it gets the job done.
'06 2wd le cc six inches taller, 2"prg spacer front with 4" cst spindles, sway bar removed, 1.5"blocks rear with 2"aal and adj shackles, magnaflow, k & n cai, plastidipped black grille, rattle can bedliner spray on sidestep tubes and most other exterior plastic. 285/70r17 goodyear duratrac tires, superchips tuned, calmini front pre-runner bumper, cobra cb, oem roll up soft tonneau cover, oem bug deflector and vent visors, plasti dip black stock wheels, yakima load warrior roof rack mounted over the tonneau cover, 2" B.O.R.A. wheel adapters in the rear and 1.25" B.O.R.A. adapters int he front[/COLOR]
