  #21 (permalink)
Old 03-13-2008, 12:01 PM
unibager's Avatar
Originally Posted by 07Fronty4x4 View Post
Do you have the stock tires on still or did you up-size? Also, where do you get rubbing? inside fender, outside fender, lower air dam, mud guards?
I have the stock tires, and the rubbing is only on the drivers side, inside the fender, and against the plastic. Also, I have bolt to bolt spacers, and one inch clears b ecause the nismo rims have reliefs in between the lug holes.
2005 crew cab Nismo 2wd. Electric Blue. 3" Calmini shackle lift.
  #22 (permalink)
Old 03-13-2008, 01:10 PM
bigriver's Avatar
Good info on the rims, I was wondering if that was the case. Not a problem on mine cause I have 2" adapters on my rear wheels. Probably need to use open end lug nuts if your rims don't have "relief" and you want to go with a 1" adapter.
'007 2wd Nismo PRG titan swap 5" lift, volant, s-tune catback, luminum diff cover, 350z tstat swap, superchips cortex
  #23 (permalink)
Old 03-13-2008, 02:26 PM
07Fronty4x4's Avatar
BigRiver, I was looking to do 1.5 inch adapters all around on Stock SE rims, you think I'll be okay? I dont' want any rubbing.
  #24 (permalink)
Old 03-13-2008, 03:52 PM
the007forum's Avatar
I would watch out. take some measurements. i have 1.5" on stock SE Rims. But im running 33" tires and 6" of lift. My left side had no issues at all but i had to do a toooooooon of cutting on the right.
I like Mud.
  #25 (permalink)
Old 03-18-2008, 03:44 PM
Well I'm not looking to go any bigger than a 32 inches on tires and I'm looking to do 3 inches of lift. I've already removed the skirting cause it makes the front end look a ton better. So where can I expect to run into places that need to be cut?
  #26 (permalink)
Old 03-18-2008, 07:16 PM
If you have to do any cutting, it will be on the inner plastic fender.
I like Mud.
  #27 (permalink)
Old 05-11-2008, 11:44 PM
fortrak's Avatar
what is the widest spacer anyone has seen or used for our truck...like 3 inches or wider? is there any safety issues with going wider?
{2006 XE}
Exterior: Billet Grilles/Halo Projector Headlights/LED Tails/Black XE rims
Interior: Wet Okole Seat Covers/Pioneer Head Unit/Kenwood Door Speakers/12" Pioneer Sub
  #28 (permalink)
Old 05-11-2008, 11:56 PM
bamer02's Avatar
Send a message via AIM to bamer02
someone correct me but I think .5" spacer is too thick cause our stock lugs are only 1" long. Not sure if its safe to have the lug nuts bite on only about 0.25" of thread.
1" is good. i had a set. the stock lugs go into the spacers and the nuts will go in a bored/drilled slot that it fits in. it comes with new lugs so check what bolt thread it is and you need to get new lug nuts.
wheeladapters.com
ezaccessory.com (where i got mines).
have fun...
2006 Nissan Frontier KC, CST spindles, mini lift kit(prg), 2.5" deavers (prg), ss brake lines, adjustable shackles (prg), bilstein 5125's, 8k HID, DIY 2" Body Lift, TITAN SWAP: titan upper and lower control arms, and tie-rod extensions (prg) . MB Motoring mb72 bfg at 285/75/16, CUSTOM Titan Carrier bearing drop kit, sliders, and front bumper, FET foglights, etc
future:
cherry bomb and flowmaster series 40.
  #29 (permalink)
Old 05-12-2008, 04:22 AM
i think 2 in the back, 1.5 in the front. 3 might be sketchy because the farther out your rims are, the more stretch it puts on the suspension internal components. but you might be fine.im sure there are people with aftermarket rims that stick out say 2" more and running 1.5" spacers which equals 3.5"
if your 2wd i would just do a titan swap. im not sure how much it all matters.
I like Mud.
  #30 (permalink)
Old 05-12-2008, 04:51 AM
fortrak's Avatar
why would you suggest doing a titan swap? seems like so much work/time/and money
{2006 XE}
