Old 05-05-2008, 01:37 PM
BlackTigerSE's Avatar
Originally Posted by the007forum View Post
These are the two designs im deciding between. the plate with the bolts will be welded to the frame and the bolts will be welded to to that plate inside the frame. I will use some factory holes, and drill some new ones, but it should be very strong and removable.
Hmm i think i might just get mine welded haha.
SE KC 4x4 6M M226 3.538
Old 05-05-2008, 01:47 PM
the007forum's Avatar
Im doing the one on the right for sure, but run the plates all the way up and down the frame (so that when the truck lands on the sliders all the stress goes primarily to the very top and bottom of the frame tube, essentially pushing/pulling the horizontal parts of the tube instead of pushing in or puckering out the vertical wall). It will be very easy too. ill post pictures. The guys at Ronin helped me out alot to figure out this design.
I like Mud.
Old 05-05-2008, 01:49 PM
carlsbadfrontier's Avatar
I really dont understand all of the effort put into devising a way to bolt on sliders. I am not being critical, but only asking why? If they are welded on, you are doing no damage to the frame, so that shouldnt be an issue. If you damage a slider, you cut it or the damaged part off and weld a new piece in...
I would think that welding them to the frame is the strongest and most reasonable way to do it.
Opinions? Thoughts? What am I missing here?
So come pull the sheet over my eyes so I can sleep tonight despite what I've seen today. I find you guilty of a crime of sleeping at a time when you should have been wide awake.
Down on the road the world is floating by. The poor and undefended left behind. While you're somewhere trading lives for oil, As if the whole world were blind.
Old 05-05-2008, 01:50 PM
Your missing the big picture...
Old 05-05-2008, 03:07 PM
Would you be so kind as to take a few moments out of your busy day to explain "the big picture". Or is that too much to ask?
Old 05-05-2008, 03:14 PM
It appears that their overall plan is to make it removable so that they do not need to be attached all the time. This would help cut down on the total weight of the truck for its daily driving but it would make it possible to hook them back up for offroading.
Old 05-05-2008, 03:17 PM
The "big picture" has not been posted yet
Old 05-05-2008, 03:27 PM
Nissan4Life's Avatar
I think the big picture is: they don't have a welder or know how to weld.
I don't think that anyone would bolt and unbolt them for off roading.
The only reason to bolt them on is so when you want to sell the bars you can unbolt them and sell them. If welded it will require you to cut them, which might make it too short for reattaching to another vehicle.
My sliders are welded to the frame.
The only thing that I would question about the trail gear silders is how strong are they. I built mine out of tube stock with too thin of a wall thickness. I took afew hits and kindda messed up the bars. I figure I will jsut run them until they are bashed to hell, then cut them off and either make another set out of thicker stuff, or buy some pre fabbed ones. Either shrocks or these. I want to see some trail side test of them hitting rocks.
06 KC NISMO 4x4, 2" prg spacer front, Firestone riderite airbags rear, Schrockwrxs front engine skid, Custom sliders, Hidden hitch reciever, Deck plate Airbox mod/amsoil filter, Momo shift knob removed, back to 06+ nismo knob, 05 pathy flat black wheels, 265/75/r16 mud king XT studded, wireless door lock keypad, cargo light bypass, auto dimming rear view mirror with compass and temp
  #19 (permalink)
Old 05-05-2008, 03:32 PM
[quote=Nissan4Life;493094]I think the big picture is: they don't have a welder or know how to weld.
I don't think that anyone would bolt and unbolt them for off roading.quote]
Idk about the welding part but 007 did say that the plates and nuts were going to be welded on so I assume he is going to pay someone do it or do it himself.
Personally I wouldn't take them off when I am not off-roading but I guess others have their own reasons too.
  #20 (permalink)
Old 05-05-2008, 03:46 PM
ill try and answer some questions but im a little confused myself. Yes, i will be welding alot for these. If i didn't want to weld i would have bought premade shrock sliders. If you wanted to, you could take these off when your just driving around but that would be alot of work. Mine will be permanent but i want to be able to remove them paint them, take off body lift when i SAS, and if they become damaged. Alot of it depends on how you are going to use them. i am going to be constantly slamming my truck on them because there is alot of rock wheeling out here. If your only using them occasionally, you would be safe with factory mount spots. but my big picture is the long run. the welds will be much stronger than the frame, and over time in verrrry small increments the weight of your truck on the sliders could bow your frame. what im doing is alt more than what is really required, but i will be 100% sure they are strong and i wont cause any damage to my frame, yet be easy to remove. its just taking extra precautions.
I like Mud.
