I wouldn't run any 100w or 130w bulbs in the Hellas unless you are willing to upgrade your harness. Otherwise, you really are going to be running the risk of melting it.
Your best option would be a 55W Narva Rangepower +50. More light, but still 55W. Only problem is the lifespan of the bulb will be significantly lower.
Narva® RangePower+50® Ultra High Output 55w H3 Bulb
There are also some selective yellow bulbs on the candlepower.com store if that is what you are looking for.
H3 bulbs
Cheers
-Jeff
