Old 07-30-2008, 09:43 PM
mike's Avatar
Puddle lights?
It's time for me to start working on a puddle light system and need a few ideas.
What did you use?
Where did you mount them?
How many are you using?
How did you wire them?
Pic's are always helpful.
Old 07-30-2008, 09:54 PM
Are you looking for a streetglow or LEDglow type of thing for off-roading? I would also suggest that you go with an LED set-up over a tube set-up because it would be a lot easier to break a tube then compared to an LED. Also, power consumption is greater with the tubes over LEDs.
Good Luck.
I think there are also a couple guys on CT that have done this mod.
Old 07-30-2008, 10:02 PM
nebraskafrontier's Avatar
i mounted 8'' white led strips under each door right behind the pinch weld. they are not visible unless you are under the truck. they are wired into a relay set off by the bed light, that way when i unlock the truck they come on or when i hit the bed light for setting up camp. it works well the only problem i have is they get muddy kinda quick and after the lift and tires they dont light up the ground as well.
i plan on installing some brighter lights if these ever break, im just waiting for them to get hit by a rock.
2006 SE kc. 4x4 6spd. Storm gray. calmini 2.5'' lift. 255/85 Maxxis Bighorn(ey)s. De-badged.
No person was ever honored for what he received. Honor has been awarded for what he gave.
- Calvin Coolidge
Old 07-30-2008, 10:18 PM
mike's Avatar
Originally Posted by dubie2003 View Post
Are you looking for a streetglow or LEDglow type of thing for off-roading? .
No.
nebraska, do you have any pic's of them mounted?
Old 07-30-2008, 10:23 PM
Mr. Plow's Avatar
Im not sure if you saw mine at GWNF Mike, but I just mounted some cheapo "Walmart" fogs to the top of my rear axle, and wired a simple toggle switch in the cab. They worked well as aux backup lights until light housing filled w/ water. I removed them and will just buy another more heavy duty set of lights. I didnt want the lights hanging down so they could get crushed, that is why I picked on top of the axle as they are well protected up there except maybe for the stray bit of gravel kicked up by the front tires. Also the AC rear diff skidd provided a good place to attach the lights to
Silver 06 Frontier KC NISMO 4x4. Mods: PRG Radflo 2.5" SL; Deaver 10 Leaf Springs; AC Rear Diff Skid; Shrockworks Sliders/Skids; KMA Front/Rear Bumpers; Warn M8000 Winch and Offroad Lights; Gibson Exhaust; Interco Trxus MTs 285/75/R16 on MB Predators
Old 07-30-2008, 10:26 PM
Originally Posted by mike View Post
No.
i dont have any pics but i can probably have them up by tomorrow. my camera charger is at work. the only thing that might be a problem for you would be light interference from your sliders.
i was going to mount them in my side mirrors and dremel out part of the bottom to mount them flush, but buying the bulbs for that would of cost a bunch more and my truck was fairly new and i didnt feel like cutting it up yet.
- Calvin Coolidge
Old 07-30-2008, 10:28 PM
mike's Avatar
Originally Posted by Mr. Plow View Post
Im not sure if you saw mine at GWNF Mike, but I just mounted some cheapo "Walmart" fogs to the top of my rear axle, and wired a simple toggle switch in the cab. They worked well as aux backup lights until light housing filled w/ water. .
I look at the walmart ones and saw that they where not sealed. I don't know where I could mount them so they would not fill with water.
That does sound cool.
Old 07-31-2008, 04:43 AM
8o8blkfrontier's Avatar
my friend had it done to his titan he used about 5 white singles lights im tryna get him to e mail me pics of what it looks like. ohh his titan is lifted 10in with 20's and 35in tires and the puddles still show just a little bigger.
Exterior:dual borla exaust with 3 1/2in pipeing,street glow,smoked out tail lights,smoked out third led brake light,6000k H.I.D,billet grille,led license plate lights,airraid throttle body spacer,5%tint on back, windows double 5 on fronts,Clifford 50.5 alarm w/ remote start,optima yellow top 5" calmini lift
Interior:all in one Valor double din,9.2 in headrest monitors,led dome lights,DD 9510 sub,DD m1b amps
Old 07-31-2008, 10:49 AM
Mylt1's Avatar
hit up ebay for the brightest LEDs you can find WITH RESISTERS and then head over to rat shack and buy a couple of hobby boxes. then design your own using the boxes as the mount for the lights.
05 LE CC 4X4. SUPER BLACK
Old 07-31-2008, 03:03 PM
mudyfronty05's Avatar
I have a friend that used the cheap tractor lights from Tractor Supply-he mounted them inside the frame rails.
No pics, sorry.
'05 EB CC NISMO 4X4 MODs-Nissan toolbox-PRGproducts. com 3in lift with T\C arms, radflos and Deavers,Bilstien 5125's-265/75R16 Firestone Destination M/Ts-Volant Cold air intake!, Trail Gear Rock sliders
