Problem with BakFlip
I have the BakFlip tonneau cover on my truck and it is falling apart. It seems the adhesive cant stand the summer heat here in Houston. I called BakFlip and someone pickup the phone right away (which is very rare these days). They said they had a batch of bad BakFlip and I may have on of these. They have since resolved the problems and will send me some replacing parts. They also have an upgrade version coming soon.
I think their support is outstanding, but will have to wait and see if the replacment parts look any good. |
My adhesive is starting to melt away as well. I have also recently noticed that where the struts mount to the middle of the cover there seems to be a buldge on the ends. When I disconnect the struts the cover levels out, it is as if the struts are to strong or something. I liked the cover at first but after only 5 months of use it is starting to fall apart and I would no longer recommend it to anyone else.
06 BLK SE CC, PWR PKG PERFORMANCE MODS: Volant intake, JBA SS Exhaust, Grounding kit, WRP IMS, 2*advance EXTERIOR MODS: OEM Step Rails, OEM Body Moldings, OEM Splashguards, OEM Bug Shield, OEM FogLights, OEM Nismo Wheels |
I just got one also and am finding that the adhesive is also not doing it's job. I'll have to get ahold of them also.
just called BakFlip and they are also sending me the replacement adhesive strips. they should have done some more R&D on this cover. otherwise it's a great cover. Last edited by blazers27 : 06-18-2007 at 05:42 PM. |
They offer me the upgrade version of the BlakFlip free of charge! Hopefully, they make some improvements in the new version.
Beside the weather strips, please check the aluminum housing for the cable to release the latches. On mine, they used double sided tapes to attach the aluminum bar to the panel. The glue on the double sided tapes also fail after a while. |
Will
I don't have a place to upload the images. But yours looks quite different from mine. For example, looking at the first picture, my cable channels do not have any rivets, event the two pieces at the corners are only attached to the panel by double-sided tapes. They told me that "The cable housing units are now being riveted on and we no longer use glue." So it looks like you have the newer version.
About the rubber strips, here is what they told me: "Regarding the weather stripping, there was a 6 week process where the manufacturer of the seal removed the rubber from the curing process too fast, causing the rubber to shrink and therefore the seal would peel up. We are very aware of this issue and have sent replacement seal for all these covers." |
I have the newer bakflip i had them send me a replacement cover once because of the seal on top being install wrong. the second one has been on about a month and the 2nd panel is starting to warp where the strut attaches to the under side of the cover i will be returning them both for a refund will be going with the new g4elite from fold a cover its aluminum with ss hinges thay have them listed at truckaddons.com. i spoke with a sales rep at fold a cover and he said the new cover won't be out for another 4-6 weeks.
It would really help if some of you could post pics of your covers which have problems. You don't need to host the photos anywhere, just click the "manage attachments" button when entering a new post and you can attach them directly to your post. Or you can PM me and I will send you my email address so you can email the photos and I will convert and post them for you. |
