  #21 (permalink)
Old 01-30-2008, 08:29 PM
nizmut's Avatar
Originally Posted by dubie2003 View Post
You can also place them in the rear if you do not have a reciever hitch. The only issue is that if you offroad, it doesn't help your ground clearance when you are dragging your rear end over a hump. I think I have read the you can actually get them stuck on roots and stuff that will hang you up.
but since they sit higher than your tail pipe and bumper the hook is not the only thing getting hung up.
  #22 (permalink)
Old 01-31-2008, 01:45 AM
peter's Avatar
Originally Posted by mike View Post
I have the tow hook in the rear.
On 3rd time using it (I was high center really bad) The frame where it is bolted bent alittle inward.
Thanks for mentioning that! I think I'll go and make a cross brace for mine to stop this from happening.
Regards
Peter
  #23 (permalink)
Old 06-06-2008, 07:00 PM
keahi89's Avatar
rear install
anybody have any closer pics of the install in the rear??
where exactly would you bolt it on?? pics would be great.
thanks everybody!!!
spam & eggs, easy ovah, rice
2008 crew cab se
  #24 (permalink)
Old 06-06-2008, 07:06 PM
I find that I end up banging the tow hook while off-roading. Nissan should have located the hook higher and not hanging down, similar to the Titan.
  #25 (permalink)
Old 06-06-2008, 08:15 PM
keahi89's Avatar
yeah, i'm more of an urban guy so i don't foresee too much off roading. maybe a dirt road or beach now and then. so i don't think i'll have a problem w/ the placement. anybody w/ pics or detailed explaination of where it goes? i've read elsewhere that you put it where the tow hitch would go but i don't know where that is. i've look underneath and have seen some threaded holes in the side of the frame, but still not sure. a little help please. thanks!!!
2008 crew cab se
  #26 (permalink)
Old 06-06-2008, 09:10 PM
mike's Avatar
thanks everybody!!!
  #27 (permalink)
Old 06-06-2008, 10:41 PM
nizmut's Avatar
might want to run a flat plate through all three bolts to stiffen the frame. I snatched Mustard out after the jeepers winched on him for a hour and a half. Bent my frame so bad I had to unbolt the hook to get the strap off. All so snatched Hustonics out a few times that day. Of course I might be a little hard on my truck
  #28 (permalink)
Old 06-09-2008, 07:26 PM
keahi89's Avatar
thanks for the pics guys. so it looks like it bolts to the BOTTOM of the frame. i saw some threaded holes in the SIDE of the frame and i thought those were the ones. thanks again!!
2008 crew cab se
  #29 (permalink)
Old 06-17-2008, 04:57 AM
kyleb's Avatar
Originally Posted by stevet47 View Post
No, they only make 1 hook. You have to install it in the same exact orientation as the stock hook, you can't flip it around to make it "look right", or else, like you said, the hook would be pointed the wrong way.
Hi all,
I own a Navara (right hand drive version) and it has the tow hook on the left from factory. I recently ordered the right hand tow hook from the nismoshop (thanks to Justin for his assistance). The tow hook arrived today and bolted straight on (no cutting required). The original tow hook is a mirror image of the one I ordered, so it appears that Nissan do make 2 different hooks, one for RHD and one for LHD Frontier/Navara. Not sure how much the dealers here would charge for the replacement LH tow hook, but if anyone is interested I can find out and let you know
  #30 (permalink)
Old 06-17-2008, 12:26 PM
Mainerunr's Avatar
Originally Posted by kyleb View Post
Hi all,
please do. thanks.
Similar Threads
Tow Hooks Frontier2 Buy/Sell/Trade 11 07-10-2007 09:51 AM
tow hooks chrisxk2 Exterior Mods 1 06-29-2007 02:21 PM
rear tow hooks penski61 Exterior Mods 10 04-23-2007 10:16 PM
1st Gen Tow Hooks JoshuaTest 1st Gen Hangout 20 02-07-2007 11:22 PM
Front tow hooks grampy Exterior Mods 50 02-03-2007 05:49 PM
