OEM Front Tow Hooks
A few of you were asking, so I put these on the website today
The Nismo Shop : West Covina Nissan : Nissan OEM Front Tow Hook :: 05-08 Frontier The front tow hooks did not come on XE models, also Jay and Zack figured out that these will bolt onto the rear of our trucks as long as you are not running a reciever hitch. Ill have pics up in a couple days.
West Covina Nissan 205 N. Citrus St. West Covina CA www.thenismoshop.com 626-732-1000 x6375
Will these work on either side of the truck (if I already have one and want to put a second on the front)?
![]() Clubfrontier Rules and Guidelines Report a bad/flaming/illegal post by clicking on or ![]() 2nd gen FAQ Where to legally 'wheel in the Southeast |
I think it CAN work, but it doesn't really "fit". You'll have to cut a part of the valance out for it to poke though, and it will be a couple inches too far to one side.
Also, I have some pics of a hook on the rear of my truck, but I can't get to photobucket at work, so I'll have to post it tonight if no one else gets one up before then.
05 Frontier KC Nismo 4x4. 255/85R16 Maxxis Bighorns, 2.5" PRG lift, Demello Sliders, Shrockworks Engine, Front/Radiator & Gas Tank skids, 15# Ultimate Air CO2, WRP Crank Pulley and IMS, Fujita Intake, Slotted Rotors/EBC Pads, Braided Brake Lines, WRF Lightbar with HID converted Hella 500s. In the works: Custom re-built leaf springs, custom rear diff cover, u-bolt flip. |
You can install an extra one on the front but you have to cut a hole in your lower plastic piece "valence" and then you also have to trim your front skid plate a little. It is thin metal so basic tin snips work. You just have to keep trimming till it fits. It only took me an hour or so to finish it. Most of the time was spent on trimming and fitting thou.
You can also place them in the rear if you do not have a reciever hitch. The only issue is that if you offroad, it doesn't help your ground clearance when you are dragging your rear end over a hump. I think I have read the you can actually get them stuck on roots and stuff that will hang you up. |
WELL I GUESS I SHOULD SELL MINE THEN FOR LESS, OFFERS?????
does nissan make 2 different tow hooks? One for each side? I've attempted to install the hook on the other side and it ends up going on backwards so if you actually put a rope to it to pull yourself out of something you'd loose your front bumper
![]() 06 6speed 4x4 Nismo edition - NISMO CAI and rancho quick lift |
I do not think that Nissan made one for each side for the Frontier. I know there was a post from someone who took one and cut it up and then welded it back so that he had a left and a right. He then had it chrome plated. IDK how well it would hold up when using it as a recovery point since it it pretty thick steel and idk if the weld would completely penetrate it.
I only put an extra on my truck to make it look symetrical. If they did come out with one for each side, I would probably buy the correct one to make it look and function. |
No, they only make 1 hook. You have to install it in the same exact orientation as the stock hook, you can't flip it around to make it "look right", or else, like you said, the hook would be pointed the wrong way.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tow Hooks | Frontier2 | Buy/Sell/Trade | 11 | 07-10-2007 09:51 AM |
| tow hooks | chrisxk2 | Exterior Mods | 1 | 06-29-2007 02:21 PM |
| rear tow hooks | penski61 | Exterior Mods | 10 | 04-23-2007 10:16 PM |
| 1st Gen Tow Hooks | JoshuaTest | 1st Gen Hangout | 20 | 02-07-2007 11:22 PM |
| Front tow hooks | grampy | Exterior Mods | 50 | 02-03-2007 05:49 PM |
