Mud Flaps - Page 4 - Nissan Frontier Forum
post #31 of 76 (permalink) Old 11-07-2012, 11:51 AM
MeanFrontier's Avatar
Originally Posted by noob View Post
Because of your tire size, and your driving "syle" (... since you comented on my ability to work a screwdriver ...) your opinon/experiance is different from mine...
Sure, its possible the tiny ( car size ) mudflaps and your ( 285/75 ) tire combo, they dont fold back ( @ WOT ? ) from spray... and you state they do fold back at freeway speed ... even know for the same reason ( the *tiny* flap, behind a *big* tire. ) they should be in the "draft" ( and not move ) behind those tires ...
I still think mine ( ur's ) are soft, on my ( rallycross/winter commuter ) car. ( a subaru wrx ) I do drive @ WOT in dirt, and @ the limit on the highway.
I wasn't intending to insult your screw driver ability, ha ha! I was just stating that you may have mounted them to low, causing them to be more flimsy.. Also the flaps certainly don't "draft" off the tire, being that the flaps are mounted (on my truck) about a half inch outsided the tire.. Because spray obviously doesnt just go straight out the back! That also is the reason that at some points they do move at freeway speed when you get a cross wind. By no means are they consistently blowing backwards the entire time. IMO they reduce spray very well, they dont keep every rock or bit of mud from hitting the truck but what flap does... and they also look good.
2010 SE Crew Cab 4X4 4.0L V6
Night Armor Gray
3" spacers in front, 1.5 in shackles and blocks in rear
Rocker panels and Fender flairs Line X'd
Debadged
Alpine CDA-105 Viper 5107
Doug Thorely Long Tube Headers
High Flow Cats
Custom pipe, Magnaflow dual in single out 22" long, wide body exhaust with two 18" Magnaflow resonators
K&N CAI
2 degree timing advance
285/75/16 Hancook Dynapro ATMs
16x8 inch Eagle Alloys 185 series
KMA Black Steel Bumpers
Steel tailight covers
Bully Dog GT Tuned
MeanFrontier is offline
post #32 of 76 (permalink) Old 11-07-2012, 09:46 PM
noob's Avatar
good mud flaps - Tacoma World Forums
http://www.cardomain.com/ride/255360...ro#25536090001
noob is offline
post #33 of 76 (permalink) Old 11-07-2012, 09:50 PM
Those are no different from the RallyArmor only he added that dinky weight at the bottom! The same stuff you have said about the RA's would apply to those also bro, lol! If that chunck of aluminum makes them so great you could just add it to the RA's!! Otherwise the flap is the same dam material, Noob!
Night Armor Gray
Debadged
High Flow Cats
K&N CAI
Bully Dog GT Tuned
post #34 of 76 (permalink) Old 11-07-2012, 10:10 PM
noob's Avatar
RA v. Sparco
noob is offline
post #35 of 76 (permalink) Old 11-07-2012, 10:13 PM
RA v. Sparco
Those are not universal RA flaps! Those are flaps designed for a specific "car" the universals that I have on my truck are the same size as the Sparco flaps!
Night Armor Gray
Debadged
High Flow Cats
K&N CAI
Bully Dog GT Tuned
post #36 of 76 (permalink) Old 11-07-2012, 11:17 PM
JettyLife's Avatar
Quoted: 46 Post(s)
The guy in the thread even said they're about the same size as the stock flaps.
My RA's came in today. They're only about 2-3 inches longer like someone previously stated. We'll see... they were only $25.
Sent from my SGH-T959 using AutoGuide.Com Free App
2012 SV CC: Bakflip G2, 265/70/16 Hankook ATM's
SOLD - 2010 P4X CC
LED conversion
South Jersey
JettyLife is offline
post #37 of 76 (permalink) Old 11-07-2012, 11:39 PM
$25 from where? I think mine were like $159. So the Universal RA's are even bigger than the sparco? I figured they were close, but 2-3 inches is fairly significant..
Night Armor Gray
Debadged
High Flow Cats
K&N CAI
Bully Dog GT Tuned
post #38 of 76 (permalink) Old 11-08-2012, 02:52 AM
JettyLife's Avatar
Quoted: 46 Post(s)
Rallyarmour.com I think it was? They are approximately 3 inches longer than stock. I cannot vouch for sparco's size though.
Cost me $32 shipped for their basic flap.
SOLD - 2010 P4X CC
LED conversion
South Jersey
post #39 of 76 (permalink) Old 11-10-2012, 10:23 AM
ScottB1982's Avatar
Quoted: 9 Post(s)
Send a message via Yahoo to ScottB1982
I used this basic idea brought up earlier in this thread:
I took an old ratchet strap and cut it to lengths and used them to keep the flaps from flexing into the tires, potentially tearing them up or ripping them off... even if they may look...different. The next holes down definitely add considerable length at the bottom of the flap, but now I have less side coverage. When they were higher and further out, though I was still getting mud spray on the rear areas everyone gets chips on, so I think the problem is from the bottom of the front tires. Of course, with my wider tires and lift, it will be a tough compromise to keep the rocks off the paint and having the mudflaps where I WANT them. I'll try to find some gravel and/or mud to drive through to see how much they block now. I'm ready to hear the criticism on them now, as the straps might seem "rice" to some people, but there was a big possibility of them rebounding right into the tires with them being lower, allowing more flex. The straps DO have a true function. I pulled the flaps all the way back and let them go, and the straps stop them perfectly. If I get too much spray from the exposed part of the tire not covered by the flaps, then I'll adjust a bit higher or angled to get better coverage, but as I mentioned, I think the biggest issue has been from below where the flaps were covering before I moved them this time.
The earlier position had minimal flexing for me at highway speeds, for those who were wondering. ON TO THE PICS!
ID:	39589   Click image for larger version
ID:	39590   Click image for larger version
ID:	39591   Click image for larger version
ID:	39592   Click image for larger version
2011 Frontier CC SV V6- CST Spindles, MK84 Coilovers, Custom leaf packs, 5125 bils, PRG adjustable shackles, 285/75R16 Falken Wild Peaks,N-Fab step bars, Hypertech, AEM DryFlow drop-in filter, Custom prerunner bumper made by CrewMaxxis
ScottB1982 is offline
post #40 of 76 (permalink) Old 11-10-2012, 10:34 AM
Mhannis's Avatar
Quoted: 7 Post(s)
Send a message via MSN to Mhannis Send a message via Yahoo to Mhannis Send a message via Skype™ to Mhannis
i think the whole truck setup looks pretty sweet. the little red that the straps add is kinda neat too. appearance wise...very cool IMO. as you said though, if youre still getting the chips in the quarter panels from the front wheels. their practicality may not be the sole benefit to doing this. looks cool, but functionality id put at 50/50. i think the only real way to protect fully against rock chips in the wheel wells is going to be the rhino line.
Mhannis is offline
  Nissan Frontier Forum > Mods and Technical Discussions > Exterior Mods
