Old 09-07-2007, 07:04 PM
Yarricc's Avatar
Mirrors
Does anyone know if its possible to put the towing mirrors from a titan on a frontier??? The mounts look to be the same but I don't know for certian.
2007 Frontier CC SE 4x4. Black on grey value truck package.
Nismo CAI
Factory Fog lights
Precision Billet Grills
Old 09-08-2007, 12:55 AM
Frontier2's Avatar
I don't know who,but someone on here bought some to try out but i never heard anything else about it.
06 MAJESTIC BLUE 4X2 LE KC
Old 09-08-2007, 01:01 AM
from another thread
Originally Posted by stevet47
They will fit, but I haven't looked at one recently, so they may be a little different though, but I THINK they are the same.
All I know is that Titan mirrors will not fit, because I wanted to put them on, but they bolt on differently.
Frontier Mirror Replacement
06 CC 4X2 6sp Avalanche White NISMO SPORT
Series 77 K&N CAI*Gibson SS Catback* Power Aid Throttle Body Spacer* 2 degree timing advance*Helper Leaf Springs*7 point Grounding kit*TB mesh delete mod*Hyper White Xenon Bulbs 5000K Temp*Sport Track Bike Rack*Pilot 330C Fog lights*20% Tints*Red Calipers*black SE wheels*Euro style smoked tail lights*vinyl smoked third brake light*stubby 14" antenna*debadged*custom mesh grill powder coated black *APC aluminum pedals*aluminum shift knob*LED interior lights*OEM All weather mats*Pathfinder switch covers
Click on the picture for my Frontier thread
Last edited by Shift_Avenger : 09-08-2007 at 01:02 AM. Reason: Automerged Doublepost
Old 09-08-2007, 01:05 AM
stevet47's Avatar
I was thinking about doing the same thing, I don't think it will work.
The way they bolt to the door is different, we have 3 studs in a triangle pattern, and the Titan has 4 studs in more of a square pattern.
The only way it MAY work, is to just swap the Titan's mirror head (the part that pivots) onto the Frontier's stock arm (the part that bolts to the truck).
EDIT:
Alright, here ya go.
Frontier Mirror
Standard Titan Mirror
Titan Big Tow Mirror
I suppose if you could get your hands on a Titan mirror you could try it out to see if the shape even contours to the Frontier's door, if it does, maybe you'll luck out and just be able to drill the mounting holes you need.
05 Frontier KC Nismo 4x4.
Old 09-08-2007, 01:25 AM
HKYStormFront's Avatar
wow, the bolts do actually look like a similar pattern, it might just work, if it matches the doors contours as steve said... let us know!!
Patrick
Mods: lots...
Old 09-08-2007, 01:28 AM
stevet47's Avatar
hmm.... no they dont. We have 3, Titan's have 4, and they arent even close. Remember, the top pic is the Frontier, the botton 2 and Titan.
Old 09-08-2007, 01:50 AM
holy crap, i'm more tired than i thought, you are right steve, my bad still if it matched the contour, and the wiring harness was the same, i'd do it!
Patrick
Mods: lots...
Old 09-08-2007, 01:56 PM
Yarricc's Avatar
my boss has a titan and the contours look the same I might have to just order one from my local dealler and see. I want the towing mirrors for added visiblity.
Nismo CAI
Factory Fog lights
Old 09-08-2007, 02:08 PM
stevet47's Avatar
Before you buy from the dealer, try this website:
http://www.mypartshop.com/
These were the results I got using Oregon as my location (you could narrow it down with your zip code) and searching for the Non-Memory Big Tow Mirrors:
http://www.mypartshop.com/EOL_PublicSearchResults.aspx
I got a mirror for my girlfriends Ranger from a local junkyard after a search on this site and saved $70 over the dealer. Yes, it is used, but the mirror I got was in absolutely perfect condition.
Old 09-09-2007, 01:45 AM
carphreak's Avatar
from the above posted manuals, i would say that a generous amount of trimming and fiberglass work will be involved and quite possibly modification of the bolts....
you can put any side mirror on your truck but the question is how much work are you willing to do? the titan and fronty do not look like a straight swap/bolt in....
just as confused as you are
