Joey-moded mine . - Page 2 - Nissan Frontier / Navara Forum
Old 12-06-2012, 03:39 PM
noob's Avatar
Originally Posted by Mhannis View Post
i like it. wouldnt mind doing this to my sentra if they werent already tinted lol
LOL, Peel it off and do this ! : o)
Old 12-06-2012, 08:23 PM
noob's Avatar
Not a lot of before pics, and I put the grill back, so its not spread out all over the sidewalk/lawn ...
Facebook
Old 12-07-2012, 01:56 AM
JettyLife's Avatar
Insane that we have to remove the upper bumper piece to remove the head-lights.
Sheesh
2010 P4X CC: 2.5in/2in Lift (ADF&PRG), SPC UCA's, Xoskel Bumper Mouth Bracket w/ 4 Rigid Industries Duallys, Superchips Tuned 87 Performance w/WOT Removed, Kool Vue CAI, Rear Axle Vent Mod, Bakflip G2, Radiator bypass, LED conversion.
In Progress: 285's, IMS, exhaust, LED courtesy lights, super on the down-low LED light bar project, Cargo light delete, skids, LED reverse floods, coilovers
South Jersey
Old 12-07-2012, 09:15 AM
noob's Avatar
You dont have to...
but by the time you take out all the fastners from the side, so you can peel back that upper bumper trim piece and get to that ONE bolt, on the side of the headlight. You might as well pull the whole thing off.
That thing is kinda trick-y to get out even after you take all the fastners out ... it has a "fin" that drops down behind the sides of the bumper AND another that goes flat under the headlight. The center of it tucks down and under the crome bumper and into the actual steel bumper/frame...
Old 12-07-2012, 09:35 AM
Zero Six LE's Avatar
Originally Posted by noob View Post
Negative, they are trunk carpet fastner pliars... they make super-fast "work" of the easy part, that way you dont get too frustraded ( scratching, stabing, breaking ) BEFORE you even get to the hard part.
Pic of the hard, of fun if you a mashocist part, two 10mm bolts holding the under headlight/upper bumper trim in place. You can kinda see the blury onr, then his buddy is a little higher. ( also 2 gide pins )
I use a 10MM ratchet wrench to remove those bolts holding the upper bumper fascia in place.
The Following User Says Thank You to Zero Six LE For This Useful Post:
x_mods (12-07-2012)
Old 12-07-2012, 07:16 PM
x_mods's Avatar
Sheesh
It's even worse if you have the one piece plastic bumper! Add another 12 fasteners, 22 if you still have the air dam installed.
The Tacoma's have a little trim piece under the light so you don't have to take off the whole bumper. But I have broken every one of those little pieces I have tried to remove... I still have yet to break my bumper
-Nate
Old 12-10-2012, 11:13 PM
noob's Avatar
No snow, but plenty of rain... I'm gonna drive around as much as posible, and check for leaks.
Old 12-10-2012, 11:18 PM
noob's Avatar
Doing this next :
... only takes/costs a sharpie or 2 ...
