Amber LED Running Lights Under Headlamps - Nissan Frontier / Navara Forum
Old 12-31-2012, 11:06 PM
Coming soon.. Have done mod before to a Tundra.. Looks factory when finished.. LED's on with ignition, or can be connected to signal only, or both, as desired.. You can use amber, or white, ... or white running with amber signal, if you wish.. Pics and info will be posted when done..
Old 12-31-2012, 11:08 PM
JettyLife's Avatar
Can you throw up a shot on the tundra so we can have an idea?
2010 P4X CC: 2.5in/2in Lift (ADF&PRG), SPC UCA's, Xoskel Bumper Mouth Bracket w/ 4 Rigid Industries Duallys, Superchips Tuned 87 Performance w/WOT Removed, Kool Vue CAI, Rear Axle Vent Mod, Bakflip G2, Radiator bypass, LED conversion.
In Progress: 285's, IMS, exhaust, LED courtesy lights, super on the down-low LED light bar project, Cargo light delete, skids, LED reverse floods, coilovers
South Jersey
Old 01-01-2013, 08:52 AM
Tundra Sample
Frontier LED's will be along bottom edge of lamp assy, instead of top edge as shown on Tundra..
Old 01-01-2013, 06:46 PM
YankeeVol's Avatar
can't wait to see a pic when it's done
To my countrymen I am the shield. To my enemies I am the sword.
2012 CC Pro 4X
Old 01-02-2013, 12:55 PM
I'd like to add something like these switchback led strips from ijdmtoy:
Side Glow Switchback LED Strips | Daytime Running, Turn Signal Lights
They wedge between the bottom of the headlight housing and the bumper/valnace. It's pretty tight between the two, so you would probably need a screwdriver to initially mount and position the led strip.
Old 01-02-2013, 01:50 PM
Gadsden's Avatar
I like that, definitely looks good.
2011 SV 4X4
Old 01-02-2013, 07:22 PM
EZ
Who does that. I like the style, but would like it underneath the light assembly.
NFS
I like the white and amber change. Very cool.
2012 SV Crew Cab V6 Auto
Old 01-02-2013, 10:07 PM
Under Light Assy
Originally Posted by dave11 View Post
EZ
NFS
Yes, the LED's strips I purchased will be installed underneath the Head Lamp Assy. Until I have the time to get the headlamp assys out, I have not decided whether it will best work attaching directly to bottom leading edge of headlamp assy, or to top edge of the upper bumper body trim piece. Have to wait for cold weather to pass, and get some 3M Promoter in my hands, before taking everything apart to get it done.. The strips I have, are exactly the length needed to go under headlamp assy from bottom inside corner, to rear back corner edge below side amber reflector.
Old 01-02-2013, 10:13 PM
Use Promoter
I would not install these without using 3M Promoter, and removing the headlamp assy, before you do the job. You need to thoroughly clean the surface before applying the promoter. Without the proper prep, they may stay down for awhile, but after time, weather, etc. will get under the leading edge and the strip will eventually start to separate from the surface.
Old 01-02-2013, 10:19 PM
I m looking forward to seeing the end result. Where did you order them from?
